new to kpro software
kercha83
Post by kercha83 »
hi i am new to this kpro. I just downloaded the software from hondata then try to hook it up to my car using the usb 2 to usb wire, then when i turn the ignition to on i get a message saying " the sofware needs to be installed". After that i click install the software, then it says put in a disk or find another option. I dont have the disk so i click other option and from here i dont know what else to do. Can anybody help me out here. Am i doing something wrong.
In Kmanager, go to Help, Contents, under Installation, you will find installing USB drivers. Make sure you choose the one for your operating system and follow the instruction. It is very important that you follow the steps EXACTLY, or it will not work.
kercha83
Post by kercha83 »
i did everything exactly like how the instruction told me to do and after i browse and clicked on C:/Program Files (x86)/KManager and then clicked on next after that i get a message saying Windows was not able to install hondata k-series ecu (windows could not find software for your device)
Spunkster wrote:In Kmanager, go to Help, Contents, under Installation, you will find installing USB drivers. Make sure you choose thee for your operating system and follow the instruction. It is very important that you follow the steps EXACTLY, or it will not work.
Do you have Vista 32bit or 64bit?
kercha83
Post by kercha83 »
i have a vista 64 bit operating system.
Spunkster wrote:Do you have Vista 32bit or 64bit?
Currently it will not work with Vista 64 bit. You must use Vista 32 bit.
kercha83
Post by kercha83 »
will it be a while before you guys get it working with the 64 bit.
Spunkster wrote:Currently it will not work with Vista 64 bit. You must use Vista 32 bit.
