where to find k pro serial number ex. 4111
boostedeg
Post by boostedeg »
i just bought a prb ecu from a 2003 rsx type s where can i find the k pro serial number ex. 4111 ithink it already has some hondata program on it cuz it has the usb cable port where you plug in the cable to laptop kind new to k pros any help will help thanks :D
boostedeg
Post by boostedeg »
how do iknow if i have the reflash or the k pro program????
If you can see a USB connector in the side of the ECU, then you have a KPro inside the ECU. We can also look it up from the ECU serial number.
You can also open the lid on the ecu and read the serial number from the K-Pro board inside the ecu.
