KMANAGER COMMAND LINE PARAMETERS?
carbonctr
Post by carbonctr »
Hi Hondata
Are there any command line parameters we can use with KManager yet? Datalog/record on startup would be handy.
Another handy feature would be to autosave a datalog on closing KManager or shutting down pc in case of forgetting to save it. I've datalogged a couple of times and lost it by switching off the car ignition making my carpc shutdown before saving.
In the help file see V1.2.4 under "What's New"
carbonctr
Post by carbonctr »
Hondata wrote:In the help file see V1.2.4 under "What's New"
"? To automatically start datalogging when KManager is started use a command line parameter of 'datalog' (without the quotes). "
Nice one! I missed that as I went from V1.2.3.5 to V1.2.8. Don't think I used the car when the in betweens were released. I'll change my startup menu command line next time in car :D
carbonctr
Post by carbonctr »
Is there a way to start KManager with a calibration open and datalog at the same time?
I like KManager to open the currently loaded calibration each time it starts. I normally do this by putting the calibration in the startup folder so it is opened by KManager. I can't find a way to add the "datalog" parameter when opening KManager this way....
Make a shortcut to KManager. Edit the target to include the calibration name and then 'datalog'.
carbonctr
Post by carbonctr »
Cool....I have made a shortcut with the following target:
"C:\Program Files\KManager\KManager.exe" C:\"Program Files"\KManager\Calibrations\kal.kal datalog
It loads up okay on my laptop but will try it in the carpc this evening to see if the dataloggin works....
WORKS A TREAT!
Many thanks :D
