Broken calibrations?
LK7R
Post by LK7R »
Hi,
I'm having problems with broken calibrations. When I save calibration on my notebook ,close KManager and start up the KManager again and open that saved calibration it is corupted. Any idea what can cause that? Or what can I do in order to get it fixed / to stop KManager doing it?
Car: Euro Civic TypeR 2004
ECU: PRA
KManager: 1.2.3.5 (but it was happening even with 1.2.3.3 and 1.2.3.4)
Windows XP Professional - Czech language
Sometimes it comes up with "wrong value 0.128" could it be something that local setting ("," is used as separator rather than ".")?
cheers
Dan
Yes, it is the localization setting using , as the decimal separator, which is also the list separator.
What are your regional settings, because when testing here it works if I change the decimal separator to ',' ?
LK7R
Post by LK7R »
Here is screenshot of the regional settings.
It is CZECH but i hope you'll be able to read it from memory.
LK7R
Post by LK7R »
It is usualy hapenning when I do incremental saves / uploads of an CAL. All works until i quit the KManager. When I open it again - the KAL is corrupted. Will try to fiddle with the regional settings...
It works here, but I think windows is sending new regional settings to KManager at intervals. I've made a change for the next release which should fix this.
LK7R
Post by LK7R »
Thank you!
LK7R
Post by LK7R »
Just reporting that broken calibration problem seems to be solved.
tested in previous and lastest release (1.2.8.0)
Thank you.
Dan
Vasily58
Post by Vasily58 »
Hi guys
I've downloaded a calibration from my buddy's ECU. His ITR was tuned and dinoed at our local Hondata Dealer.
The same story with the older version of calibrations. I went trough all warnings and finally downloaded the cal.
But all the ignition cards were empty.
How can I convert the cal into the newer version (1.3.0.0) of my k-pro manager?
here's the file
You'll never get enough horses under the hood so stop chasing them
Looks like security was set. You will need to obtain the original calibration.
Vasily58
Post by Vasily58 »
Hondata wrote:Looks like security was set. You will need to obtain the original calibration.
thanks
