Estimated Change in fuel tab
WickedCivicNY
The Tab estimated change in fuel tab towards the header of smanager - Does the values it displays show percentage the percentage needed to be removed or added or the amount of value needed to decrease or increase +/- from the high fuel table ?
it's the percentage change from the autotune base table to get to the target lambda table
+ = need more fuel
- = need less fuel
this article explains it some more
http://www.hondata.net/techwidebandtuning.html
although it seems that this image has it backwards
http://www.hondata.net/images/techlambd ... hanges.gif
.. maybe they should fix it
+ = need more fuel
- = need less fuel
-nigel.
http://www.heronmotorsports.com/
WickedCivicNY
Thanks for the response but the images in the link show an actual % symbol, while in Smanager it just shows a numeric #.nscirocco wrote:it's the percentage change from the autotune base table to get to the target lambda table
+ = need more fuel
- = need less fuel
WickedCivicNY
jordancivic
