Need Calibration for h22 turbo 750cc injectors
mooky2709
Post by mooky2709 »
So like the title states i need a calibration for this so i can at least drive the lude to wisconsin to get her tuned.
i have a 97 prelude with a fully built bottom end h22 obviously the engine type with 87mm cp pistons at 9:1 comp. running a t3/t04e at 8psi just to start. she also has 750cc RC injectors if you didn't read that in my title.
i did however download cardinals calibration for his 1000cc beast and changed the injectors. i have a AEM wideband in my car as well. when i uploaded the calibration into my ecu obviously it sat there at idle kinda boggin up and down then eventually died. what should i be setting the fuel map at? any help would be appreciated.
cardinal811
Post by cardinal811 »
Probably try and change your injector size and see if that helps in the calibration
Robs97'SH
Post by Robs97'SH »
I'm running 750s but my engine is stock. The tune I've been playing with works okay , I has some faults but it might help you out.
