uploads and idles fine. no cel's or error codes. no datalogging. redlight is on with green light flickering once in a while.
tried uploading new calibrations with no luck.
thanks
cant rev past 4,000
Re: cant rev past 4,000
i had same problem last year,tried swapping distributors & ignition sys. lastly i transfer the whole engine to a different chassis and uses that same s300...and it works fine.so i concluded that it was my ecu wiring harness. may be u could try using different wiring harness..may be thats the prob.8112 wrote:uploads and idles fine. no cel's or error codes. no datalogging. redlight is on with green light flickering once in a while.
thanks
holset hatch
