newbie question?
vimport.com
newbie question?
Post by vimport.com »
I was wondering if anyone ever use a Dell computer to tune Hondata? I tried on mine, never could connect to the ecu. Hondalogger, RomEditor, downloading ROM and tables and everything else works fine. Tripple check all the connection and cableI've contact Hondata and they told me the Dell computer I'm using is not compatible. Every time I'm in RomEditor I plug the serial cable to the interface box the red light starts to blink. But if I close out of RomEditor and open Hondalogger then everything works fine, connection to the ecu is not a problem. If anyone out there have any advice or share similiar issues please reply asap. T hanks :x
AndyE
Post by AndyE »
I have a Dell laptop that I use for tuning (an old 400 MHz celeron Latitude). I can reproduce a similar problem if I connect the serial cable to the laptop before the car is actually started and running. The solution for me is to disconnect the cable from the laptop, start the car, then reconnect the cable and connect with Hondalogger/Romeditor. This works for me.
Interesting that Hondata says it's a Dell problem. I hadn't heard that.
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
see2k
Post by see2k »
AndyE wrote:I have a Dell laptop that I use for tuning (an old 400 MHz celeron Latitude). I can reproduce a similar problem if I connect the serial cable to the laptop before the car is actually started and running. The solution for me is to disconnect the cable from the laptop, start the car, then reconnect the cable and connect with Hondalogger/Romeditor. This works for me.
-Andy
i was having issues with my inspiron 8100, but I guess now that the laptop is really old, (p3 1gigahertz) it started working :)
anyways I can try to help you any way I can.
I attend college at U-Si-R... Wanna start a club there?
210whp 155 wtq S200@5.5psi@7200 rpm
230whp 177 wtq S200@~9psi@7200 rpm
rebuilt engine 9:5.1 compression
271whp 236wtq S200@14.5psi@7200 rpm
1/4 Unknown
