I did find that new firmware could help me set up my launch rev limiter without having a speed sensor
I did give it a try without succes
I did put a switch on my clutch when depressed to ground E16, i did my wiring and it was not working so i put to be always on but it wont work
I did try to put it to B9 too
I finally put a rev limiter of 3000 and rev limiter did work so i know when i downlaod to ecu, the new file work
I need some help
Just dont know why it wont work
Launch controller dont work
Why when i put 4500 rpm in launch controller, the rev limit doesnt come to 4500rpm
With the old software, when i put 4500rpm in launch control, the rev limit was 4500 because the ecu doesnt read any mph so it keep on launch rev limiter
Why did you make it that way, the switch will not help at all less full throtttle shift
It so difficult to make the software to read the switch instead of mph ???
