hi,
I've just rewired the entire EF8 harness to OBD1 plugs. I used this diagram for reference. http://www.boosted.org/ecu/COMPLETE.txt
But i have a few questions, as the OBD0 wiring on the site above is not the OBD0 PW0 which i'm using now. Some pins are different and there is Vtec for this PW0 harness, so there should be some slight changes.
here is the pinout for PW0 ecu.
http://hondaswap.com/reference-material ... uts-28667/
question
1.) My EF8 harness has 2 pins for the ignitor. B15 and B17. which should i use? Should i just cut off the other?
2.) A16 alternator to B5 for alternator. But in the PW0 pintout, B5 is oil pressure switch. so should i connect D6 to B5 instead?
3.) PW0 pin B20 ignition adjustment connector, should i use it?
4.) D10 electric load detector. ELD what is this? It says connect to B19, but its the knock sensor. what pin should i use instead?
5.) A12 engine coolant temp switch to B4,but this pin is not there.
hope i can find some here here, thanks!!!
