KManager V.1.2.3.4 Beta
Do it just like I did. Always on. It will turn off once you go above the speed that you set for the transition. You just can't use the no-lift shift with it always on. If you want to do that you would need to wire in a separate clutch switch.
03' RSX Type-S
I/H/E/RBC/K-PRO/100shot/555R's
13.2 @ 109mph w/ 2.0 60'
the-anti-crack
- Contact:
