Kmanager + vista?
Twenty4/7
Kmanager + vista?
Post by Twenty4/7 »
Hi, i searched and didnt find a clear answer. I got a new laptop. I have 32 bit vista. I have kmanager installed and i can see my maps fine and look at them. But when i plug in it says that i need to install drivers. it says insert the disc that came with it and then when i click i dont have the disc it says windows cannot locate the drivers and i cannot hook up to the ecu.
Any help?
Thank you.
kistian
Post by kistian »
choose the Kmanager's directory for the search of the drivers, there's inside this
Twenty4/7
Post by Twenty4/7 »
thank you ill give it a try.
The way windows has been designed it seems that it actually tries to prevent you installing the drivers correctly.
Look in the help file under 'Installing USB drivers (Vista)'. There are step by step instructions.
