Hondata 4 Bar Map Sensor
bpatterson0004
- Contact:
is the Omnipower 4 Bar the right setting for the hondata map sensor ?
bpatterson0004
- Contact:
same different question
what's the scalar mbar/volt ? number for the map sensor and the offset mbar number ? if i read right the offset is 2 is that correct ?
My 'Hondata 4 BAR' MAP sensor reads a bit low in the Boost range..
The stock sensor would read exactly with my boost gauge.. So I knew that my boost gauge had to be accurate.. But Now that I installed my New Hondata MAP sensor.. I had to Re-tune in boost.. which doesn't make any sense at all.. The Omnipower 4 Bar MAP sensor that I had before (Which stopped working), Worked Flawlessly, and read properly.. But now the new one doesn't...
Why would it act up only in boost, and not in vacuum?
So.. It's a wiring issue, when the stock one reads fine... And the 4BAR also reads low in a friends car...Spunkster wrote:Based on the fact you have had problems with 2 sensors, it sounds more like a wiring issue in the car.
post a datalog and calibration
What I'm saying is:
The 4Bar's read PERFECT in Vacuum,.. But they read Low in boost levels.
I didn't get the chance to check the other MAP sensor in Boost, because it Failed.
airshifter
- Contact:
On the dyno right now and are seeing the same issue, s300 is saying 9ish pounds and my dyno says 20, car just made 553 with a 35r so I know it's making more than 9 psi. And like above it reads within 1psi in the vacum columns
datalog and dyno screen shot attached
Lucky for this engine I was on q16 and not pump gas, but it still didn't like the the timing for 9psi @ 20
airshifter
- Contact:
airshifter
- Contact:
