AVG version 8 fix
honda_fanatic2
AVG version 8 fix
Post by honda_fanatic2 »
If you have AVG free edition version 8 then you will need to:
-Double click on the AVG icon in (lower right corner by the system time) startup.
-Then double click on resident shield (screen shot one) and click on the manage exceptions button (screen shot 2).
-Check off the box for use excludes for the resident shield (screen shot 3).
-Click on the add path button and browse to C:\Program Files\KManager and click on ok.
-You will then see that path listed and checked off, so then you click apply and ok.
-Click on save changes (screen shot 2). You should now be able to use your K-Pro software with AVG version 8.
***If you have version 7.5 then download version 8.
poison
Post by poison »
great information! thanks
-Brandon
'92 K20R EG SM/TTE
"Most amateur drivers go too fast in slow corners and too slow in fast corners" Emerson Fittipaldi
