After driving on the 2b with no problems for 5 months, I decided to upgrade to the s200...
I had my existing fuel maps reflashed with updated software (was done on a new chip i rec'd from hondata), but once installed I got a CEL. I tried reading the code, but jumping the OBD2 hookup didn't work. Any thoughts? As far as I can tell though, the car drives fine, the s200 lights up red accordingly.
Here's my setup:
99 civic si
JRSC @ 6 psi
AEM CAI
DSM 450cc injectors + resistor pack
upgraded fuel pump
Hondata s200 w/boost
p28 ecu
My setup was dyno'd at Church Automotive in Torrance. I plan to go back to see if Sean can help, but was wondering if you guys have had similar problems.
switch from 2b to s200, now solid CEL
Re: switch from 2b to s200, now solid CEL
I had the same problem and it ended up being I was trying to use the 2.5 version ROM on the S200. It didn't like it very much. I bet it is something simple like that.drifter57 wrote:After driving on the 2b with no problems for 5 months, I decided to upgrade to the s200...
Here's my setup:
99 civic si
JRSC @ 6 psi
AEM CAI
upgraded fuel pump
p28 ecu
QUICKSILVER RACING
- Contact:
