wondering if someone has a basemap for ls vtec turbo w/ 550 cc RC injectors...GSR cams
im new to this whole hondata... if i get a base map, how do i upload it?
base map ls vtec turbo w/550cc
one_boosted_si
JDM_Honda_349
- Contact:
Not trying to jack your thread but Im also interested in what has to be done cause Im new to Hondata as well.You just upload your base map into your ecu and your able to start up and drive your car to your tuner?How well does the car run on a basemap? Dont want to run the car 2-3hrs if the basemap isn't going to run half decent. Maybe someone can answer my questions?
EG--B18c
JRSC
Hondata S300
JRSC
Hondata S300
one_boosted_si
You'll have to make adjustments to the basemap as not every car/setup is the same. Make sure you have a wideband so you can see how it's running. You can make crude adjustments to get the car running, of course, if it's a long drive and you don't trust your tuning ability then you should trailer it.
