Hello
I recenlty put a k pro in a civic Si 2003 with k24 block and k20a3 head.
In the first time the car doesn't star, The reason was the inmobilizer.
But once i started the engine and put diferents programs like tsx, k24 accord or the factory Si the car doesn't pass the 3500 rpm
I like a fuel cut.
what i can do to solve this problem?
I'm in Honduras, central america I will aprcitte your help
Fuel cut at 3500 rpm, hondat kpro
Why Honda,?? cause is the best engine
indysoccer16
indysoccer16
indysoccer16
I talked to two of my tuners and we figured out what my issue was. I got a corrupt file somewhere, either on my kpro, or on the ecu. So what we did was go to file, tools, erase ecu, then I saved my tune as another file, and I removed all of kmanager and its components. You will have to go into remove programs and remove it and also search because some files are stored under a different name in xp. then empty your recycle bin and reinstall kmanager. and upload your tune again, or try a base map before you do that. This solved my problem. Hope it helps
I resolve the problem.
the problem was the TPS. it was wrong.
Now I try with the K24 tsx stock program and run fine. we try some passes for the 1/4 mile but the header fail and break.
Because a big leak of water in the cylinder number 4.
I will wait until the car fixed again and continue to tuning
