IAT Voltage Scale
JustinC
IAT Voltage Scale
Post by JustinC »
Hondata,
I was thinking of running a PLX IAT sensor in my s/c. I was wanting to know if you could disclose the voltage scale of the stock IAT sensor so I may see if it is compatible..or if you know if it is compatible that would be great.
The PLX AIT voltage output is not the same as the stock sensor. Also there would be an issue where the ECU would try to bias the input as it expect a thermistor rather than a voltage input.
JustinC
Post by JustinC »
Ah, okay, so it is based off a resistance scale instead.
Thanks.
