ecu idle issue
kitikoune
ecu idle issue
Post by kitikoune »
what can cause the ecu to increase the engines rpms from say 1000 to 1500 at idle all the time i check for a vacum leak ???? :(
pills_PMD
Post by pills_PMD »
could be a number of things.. but here is a short list of stuff to check first:
vacuum leaks are a big one
voltage on your TPS .5 volts close 4.5 volts at WOT
is your IAC valve good?
if so, unplug the iac and use the idle bypass screw to bring the engine down to almost stallling speeds then plug the iac back in.
bleed the coolant system so there is no air in it
try those and if you still have problems repost
kitikoune
Post by kitikoune »
:? i check my tps its all good
my iac is all good
and no air in cooling system
could not find any vacum leaks
what next??
kitikoune
Post by kitikoune »
its been awhile but i still have the 1000-1500 rpm flux but its intermitant
only once the the car is warm
any ideas
Chiovnidca
Post by Chiovnidca »
What year and model?
kitikoune
Post by kitikoune »
91 honda civic w b16a w p28 ecu
DaX
Post by DaX »
check your fast idle valve.
