Hi, I am having a problem with my CRX dying at idle, especially after the car has warmed up. The idle hunts around and then finally dies. However, if I start the car when the engine is cold, it runs just fine and idles reasonably. I recently changed the igniter in my distributor which was bad, and causing the tach needle to tach out and jump all over the place. The car has a B18C1 with a T3/T4 turbo. I have 440 cc RC injectors, and I am running maximum boost at 6 psi. I don't having any stalling or hiccups at partial throttle, or WOT. Does anybody know what might be causing this? I am sure it could be a number of things. Any suggestions for fixes would be appreciated. The car is sometimes especially hard to start after it dies after being run for awhile. I can sometimes keep the car from dying at a stoplight by goosing the throttle, so the idle jumps up to around 1300 rpm or so. If there is anything else I need to let people know that might help further diagnose the problem, please post or e-mail me. Thanks.
-Todd
B18C1 Turbo CRX with Hondata Stage 2B dies at idle, ideas?
toddjlarson
toddjlarson
I am running a stock GS-R fuel pressure regulator...
Also, I am runnig a stock GS-R fuel pressure regulator, as my AEM one died...
toddjlarson
toddjlarson
I fixed the idle!
Hopefully this post might help somebody else that is having similar idle problems to what I had.
Anyway, I replaced the stock GSR fuel pressure regulator with a new AEM FPR. The idle is now right at 850 rpm. It still hunts around a little, but nothing major. I am very pleased. This could probably be totally eliminated if I turned down the fuel pressure a little more.
The stock GSR regulator was at about 60 psi, which was flooding the motor at idle. I have an aftermarket STR fuel rail and RC 440 cc injectors and this was just too much fuel at idle.
I put the AEM one at left it where AEM had pre-calibrated it, which was 48 psi or so, measured at idle with the vacuum line to the FPR pinched off.
B18C1
T3/T4
Stage 2b
T3/T4
Stage 2b
toddjlarson
