Kpro firmware version question
petah
Post by petah »
I was comparing my firmware version with my friend's and I am at 1.00 and his is 1.01. What would be the difference between the two?
edit: my serial # is 4xx and his is 1xxx.
Thanks.
Current firmware is V1.00 - I don't think that this is an issue.
Razathorn
Post by Razathorn »
Hondata wrote:Current firmware is V1.00 - I don't think that this is an issue.
How can the current firmware be 1.00 when there are 1.01's out there? I too have a friend that has 1.01, and I have 1.00. I didn't see any difference in feature set obviously, but the new firmware required the newer kmanager to work.
soberstan
Post by soberstan »
im currently running version 1.2.2.2 or something...i just updated kmanager to version 1.2.2.9? i believe...but the option for "update firmware" is not available its just shaded... and im not able to select that option...what gives?
You do not need to update the KPro firmware.
Does your frined have on-board datalogging and you don't?
soberstan
Post by soberstan »
Hondata wrote:You do not need to update the KPro firmware.
i dont?...when i try to use the K manager i keep getting a prompt to update version on the ECU?...im not able to make any changes right now...except clear codes ?
I think what it is asking is for you to update the calibration in the ECU, not the firmware.
soberstan
Post by soberstan »
Hondata wrote:I think what it is asking is for you to update the calibration in the ECU, not the firmware.
ahh yes! how would i go about that?
and one more thing...i saw another option on the k manager to disable the o2 sensor...does that mean ill be able to drive fine in closed loop w/o a secondary o2 sensor?
Go to Online, Tools and download the calibration from your ecu. After it has been downloaded upload it to the ecu. THis will update the calibration. Make sure you then save the file to your laptop.
