error code 1607
revrpm
error code 1607
Post by revrpm »
Hi All,
I had been tuning an EP3. And i got the cel light with the error code 1607 internal circuit malfuntion. Just wonder anyone of you here had this error code on the EP3.
Cheers,
What version of software are you using, what is code on the side of your ecu, and what calibration are you loading?
revrpm
Post by revrpm »
Hi Spunkster,
I am using the latest software 1.2.2.9. What you mean by the code on the side? The ecu is a PRC type.
I load in with the civic type r map that you can find in the calibration.
revrpm
Post by revrpm »
Hi Spunkster,
To be exact the error code is EGM/PGM internal circuit failure A.
Cheers,
You can't load a European Civic Type R calibration into a PRB/PRC/PRD ECU.
revrpm
Post by revrpm »
Hi Hondata,
Attach is another calibration that i had load it in. It give the same error code. hope you can help me on this.
Cheers,
Clear security.
Load the 'k20a2-rsx-stock-tuned' calibration.
If you still get the error then clear security once more and try again.
If the error is still there then is a problem with the ECU. Often the pins break on the large black plastic black component inside the ECU.
revrpm
Post by revrpm »
Hi Hondata,
The ecu is a PRD type. I had use the k20a2-rsx-stock-tuned, k20aitr and k20a2-civictyper-tune calibration. The first 2 gave the same error code 1607 ecu internal circuit malfunction. And the 3rd one saysP0141 o2 sensor heater malfunction.
So, do you think it's the black plastic component is spoil?
Cheers,
Unfortunately it sounds like your ecu is damged.
