my 424hp Map 60-1 880cc 23 psi 93 oct
Phantomhatch
Post by Phantomhatch »
The Setup:
B16a
Stock Sleeves
Victor X Intake Mani
Wiseco Pistons
Crower I Beam Rods
Block Guard
PTE 880cc Injectors
Aem fuel Rail
Walbro 255
B&M FPR
Garrett 60-1 S-cover anti surge housing
Turbonetics Evolution WG
AFI Ramhorn Manifold
ACT solid Disk
XTD PP 1900lbs
HKS SSQ
3" Down Pipe
Stock head
Total PSI was on 23lbs. This car really gets mad with 195's on th front traction im sure you can guess is not there!
This was also done on a Dynopacks as well
Total Power 424hp 283tq @ 23 psi on 93!
********NOTICE****** to whom gets this map mind you i have a 60-1 turbo 880cc injectors anda GM 3 bar map sensor.
here is the goodies
The Vid:
Image[url=http://videos.streetfire.net/video/8915 ... 24c072.htm]Lima Racing-[/img]
Last edited by Phantomhatch on Sat Oct 27, 2007 10:31 am, edited 2 times in total.
ben
Post by ben »
Do you have a datalog of the best 23psi dyno pass?
Phantomhatch
ben wrote:Do you have a datalog of the best 23psi dyno pass?
Sorry no i dont. the video was the 434 pass he never datalogged the passes. You can see the PSI in the vid of 23. :)
Phantomhatch
Here is AFR's/Boost vs. Time.
turborex
Post by turborex »
Nice numbers.
Phantomhatch
turborex wrote:Nice numbers.
thank you.
424hp at 283tq @23psi
BLUNDAR TUNED!!!!!!!!!!
Some people love him.. some people hate him.
hiperformance
Post by hiperformance »
wow, good job.
quick question, I don't know if I loaded the calibration right. I loaded it to look at it. I had to check off show 3bar tables sense show boost tables was only what i had checked from before. once it expanded I was wondering if the numbers I got were correct. say in column 15 at 6500rpm and on in the high speed ign. are you at 14 degrees of timing. am i seeing that correct?
thanks.
Phantomhatch
Yes that is correct. . we didnt want to go any more advanced due to conditions and the risk of detonation. This in turn can run a couple more degress and pump some more power! :)
Hawkturbo
Post by Hawkturbo »
What Is the engine Compresion And Fuel presure full trothel Pls thanks
Phantomhatch
The compression is 180 and the fuel press at woti cant remember at this point
cardinal811
Post by cardinal811 »
I wish Dave was on the East coast. I have a H22A waiting for him if the cost of flight and housing was feasable
Hawkturbo
Post by Hawkturbo »
Phantomhatch wrote:The compression is 180 and the fuel press at woti cant remember at this point
Hey bro pls cand you send me your mail i wana copy your engine because dont have good tuner in mi contry and i wana ask question abt your engine pls send me your mail thanks
Phantomhatch
My email is hondaruss@yahoo.com.
Airwalk07143
Post by Airwalk07143 »
thanks for the basemap. i used it on my lsvtec with 1000cc injectors and a 60-1. it actually work well. waiting to go to tuner but as of now can still drive around with this tune(no boost though :( )....anyways thanks again!!
albastiki
Post by albastiki »
thanks man and it nice job
albastiki
