Problem Seq Shift Cut. Need help.
Dominic..
Post by Dominic.. »
Hello.
Hard to find any information about it, becouse not many poeples using it.
We don`t know why Seq shift cut not isn`t work.
ECU PRA from Euro CTR .
We used all input for test (E16,E22,E29), and nothing.
In logs input signal arrived to ECU (E22BKSW) from the switch installed on Seq tramission, but ECU not cut...
Kmanager 1.2.2.8
Logs: www.hondata.pl/seq1.kdl
Cal: www.hondata.pl/seq2.kal
Thanks for any advice.
www.Ecu-Performance.com.pl
Euro CTR Boost - 1/4 12.066s ET
Sorry, currently it only works with the PRB calibrations, even though the parameters may be entered for the PRA. It will be added to the PRA for the next release.
Dominic..
Post by Dominic.. »
thank you for information.
When new release should be available? Ofcourse approximate date.
1-2 weeks.
Dominic..
Post by Dominic.. »
any good news about new release?
Oct 26th at the latest.
jostrom
Post by jostrom »
Is it possible to use this feature for full-throttle shifts in a car that has a clutch pedal switch (oem k-tranny)? Just thinking of wiring the clutch pedal swith to (PRB) K-Pro.
Anyone done it already?
marccharlton
Sequential Shift Engine Cut
Post by marccharlton »
Hondata wrote:Oct 26th at the latest.
I have tried this feature several times with differnet inputs / timings but have failed to get it working. Last time I tried it caused engine cuts at high revs with out touching the gear lever and even disconnected. It is crutial to our racing programme and must achieve flat shifting one way or another. I read on the forum others have also failed. Has anyone succeeded to get it to work? If so how did they get it to work? What is the software change that was(?) introduced in Oct? :?:
