stock H22 turbo 550cc
deafy
Post by deafy »
Need a map for stock h22 with t3/t4 turbo and 550cc. Only pushing 5.83 at the moment but going to up the boost later.
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
HDUB
Post by HDUB »
i need this too, hey deafy did u ever find one?
deafy
Post by deafy »
no i didn't but its running pretty good right now. Idle is extremely rich tho, been having o2 sensor issues. WOT is running real great, I'm loving my car all over again.
HDUB
Post by HDUB »
cool hey if u dont mind can you post ur calibration? thanks
deafy
Post by deafy »
I'd post it up if I could. Just need to find someone with a laptop to tweak out the tune and such. How much boost are you pushing and are you also using 550cc's?
deafy
Post by deafy »
Got ahold of a laptop today, heres the calibration.
HDUB
Post by HDUB »
im pushing 7bls and using RC 550 inj. hey what octane of gas r u using? ill let u know how it goes tomorrow
deafy
Post by deafy »
93 octane gas. Remember this is just a street tune, its pretty rich. It'll be even more rich for you since you're at 7 psi and that fuel map is significantly higher than the settings for 5 psi which I have set as 2 psi on the map. Timing should be alright. Get a wideband on and tune to 12:1 afr and you should be set.
HDUB
Post by HDUB »
cool it runs awhole lot better than before, wot is around 12.0-12.8, except its lean at idle 16.7 sometimes below that and on a highway cruise at 70 mph at 3000 rpm its 12.0, but i do know i have a major exhaust leak tho and thats not good for my afr readings. im getting it fixed torrow. any ways send me your e-mail, im still new to this and really would like more of your help on street tuning it.
deafy
Post by deafy »
deafy03@yahoo.com
I'm surprise it worked that well for you. Email me and I'll help you out some more. I also have a massive exhaust leak and thats screwing with my o2 sensor like crazy. I can't even street tune with it, it only reads either 9.7 or 19.7.
