Which map sensor is recommended for about 35+ lbs of boost
thudreem
Post by thudreem »
I have the GM 3 bar currently at 26 lbs of boost but I want to increase the boost. Should I go with a motorola 4 bar, or a AEM 3.5 bar or 5 bar. I want to keep a boost cut that is why I need to change from the GM 3 bar.
What works best for the s300?
Thanks,
Sean
WickedCivicNY
Post by WickedCivicNY »
AEM 5 Bar
thudreem
Post by thudreem »
WickedCivicNY wrote:AEM 5 Bar
If I do not think I will go over 37lbs should I go with the 5 bar?
Also, how is the resolution on that sensor?
planetspeed
Post by planetspeed »
This is where "More is better" works..If you do plan to boost higher, a 5bar is the way to go..
boostedcivicsir
Post by boostedcivicsir »
do it once and be done.
SFWD 1934
Post by SFWD 1934 »
boostedcivicsir wrote:do it once and be done.
I agree. Not to mention, you can alter all the load points to what you want. So you can have the 5 bar with PSI load points that go only to 35 PSI as opposed to 60 PSI.
Jason
9.86 @ 152
thudreem
Post by thudreem »
Jason
That is a very good point!! I went with the AEM 3.5 bar and did exactly what you said..!!
on a side note, do you run an ignition in your car and if so check out this thread please:
http://hondata.net/forum/viewtopic.php?t=7081
