d-j
Posts: 6 Joined: Fri Aug 24, 2007 1:43 pm
Post
by d-j » Wed Aug 29, 2007 1:21 pm
Any advice for a newb? MY01; Vortech S/C @ 7#'s; RC550cc.
Parts list has been ordered.
Already downloaded the software & looked at the AP1 sample. It's pretty basic.
TIA
Garrett_si
Posts: 254 Joined: Wed May 17, 2006 9:49 am
Post
by Garrett_si » Wed Aug 29, 2007 7:08 pm
with the S2k K-pro does the key for the immobilizer light up because the immo is disable?
Posts: 24170 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Thu Aug 30, 2007 9:46 am
Garrett_si wrote: with the S2k K-pro does the key for the immobilizer light up because the immo is disable?
The imobilizer light is controlled by the stock ecu. It will not light up at all with the K-Pro.
Garrett_si
Post
by Garrett_si » Thu Aug 30, 2007 11:10 am
Spunkster wrote: Garrett_si wrote: with the S2k K-pro does the key for the immobilizer light up because the immo is disable?
fine because in 02-04 RSX when immo is not activated, the key light up
d-j
Post
by d-j » Tue Sep 04, 2007 9:46 am
Will a Greddy pressure sensor work with this? I changed from the OEM for the emanage.
Post
by Spunkster » Tue Sep 04, 2007 10:49 am
Do you mean the map sensor? How much boost do you plan on running?
d-j
Post
by d-j » Tue Sep 04, 2007 12:04 pm
No, not the MAP sensor. The Greddy pressure sensor is a 3-bar air pressure sensor add-on. It was "required" for the emanage. "NOTE ? the peak/hold/warning Greddy boost gauge uses the SAME sensor, so you can share that sensor's output with the E-manage."
Boost will be 15#'s
Post
by Spunkster » Tue Sep 04, 2007 1:50 pm
So you are saying you removed the factory map sensor and replaced it with a greddy 3 bar map sensor?
d-j
Post
by d-j » Wed Sep 05, 2007 6:24 am
The OEM MAP sensor was replaced with a GM 3 bar MAP sensor. The Greddy pressure sensor was needed with the emanage and the boost gauge. FYI... I've given up on the Greddy emanage, the OEM MAP sensor in back on the car, currently at 7#'s. But with 15# the OEM will not work.
Will the GM 3 bar work as a replacement for the OEM MAP?
Will the Greddy (secondary) pressure be of any use? If only for the boost gauge.
Sorry for the confusion.
Post
by Spunkster » Wed Sep 05, 2007 9:48 am
You should be able to use the GM sensor as long as you use the proper scalar and offset.
If your gauges need the Greddy sensor then you should use it.
d-j
Post
by d-j » Wed Sep 26, 2007 3:16 am
Update: It's installed & running....
carlettosan
Posts: 8 Joined: Mon Dec 05, 2005 9:15 am
Post
by carlettosan » Sat Sep 29, 2007 2:27 pm
Ok then, how is it running? Getting good results tuning it?? Give us some extra feedback!
KCS2K
Posts: 1 Joined: Sun Oct 07, 2007 3:25 pm
Post
by KCS2K » Sun Oct 07, 2007 3:26 pm
I may have overlooked it on the site, does K-Pro allow for adjusting of the speedometer on S2000's with reduced final drives?
Garrett_si
Post
by Garrett_si » Sun Oct 07, 2007 6:57 pm
KCS2K wrote: I may have overlooked it on the site, does K-Pro allow for adjusting of the speedometer on S2000's with reduced final drives?
it supposed to be available
because it's a countershaft sensor, and It's thye ECU that send the Speed signal to the speedo
you calibrate it with the countershaft speed error
JustinC
Posts: 70 Joined: Mon Oct 08, 2007 9:23 am
Post
by JustinC » Mon Oct 08, 2007 9:25 am
If you hook up a wideband to the ELD input can you then use boost/lean cut ?
