b20 on boost how many pounds on stock block
i have many bolts on on my b20 how many pounds u think a b20 can take i'm trying to do at least 8pounds tuned what u think go lower or thats good .
El Verdugo
- Contact:
El Verdugo
- Contact:
Well you mentioned only bolt ons and nothing internally has upgraded, you can take that turbo to some where in the 9psi range. I am sure a little higher boost 12psi with at least some ARP head studs. I am under the impression that boost does not kill motors. High cylinder pressures due to high timing values and greater TQ numbers is the determining factors when it comes to stock internals.
Correct me if I said something erroneously, good luck though.
