Kpro daatalogging problems
BRIAN
Post by BRIAN »
Hi I have a Kprosystem, I have issues with datalogging.
the kpr works fine, only I cant datalog.
do anyone have any clues where to start trubleshooting?
Brian
BRIAN
Post by BRIAN »
Hmm, it has resistor plugs..
hardcorersxs
Post by hardcorersxs »
It must be your cable.
BRIAN
Post by BRIAN »
hardcorersxs wrote:It must be your cable.
Yes I thought so too, tried serveral Usb cables .
even diffrent computers..
Can it have anything to do with the soldering?
What is the K-Pro serial number? Will it datalog with the key in the on position, but the engine not running?
hardcorersxs
Which version of k-manager do you have uploaded? Have you installed the latest k-manager drivers onto your laptop. Make sure you have 1.2.2.6 and you re-upload your calibration. Sometimes that does the trick
BRIAN
Post by BRIAN »
Spunkster wrote:What is the K-Pro serial number? Will it datalog with the key in the on position, but the engine not running?
It will not datalog at all.
Anyone have a "how to" how solder the Kpro?
Can you answer all the questions please? We will not provide the soldering instructions as there are very small surface mount components and the possibility of damaging your ecu is too great.
Carbonltd
Post by Carbonltd »
Hey spunkster, dont mean to thread jack but thought it would be better then posting a new thread. My Kpro wont go online when the motor is running but will when the car is in the the "on" position. Im trying to datalog.
check your spark plugs and please start a new thread for issues like this.
http://www.hondata.com/techksparkplugs.html
