why im getting a knock sensor ..code 24
monty
Post by monty »
ok i have a LS/Vtec with hondata S300 NA motor with couple of mods on it ... now i got the s300 use so i re-calibrate using what it have .. so i put in a stock ITR calibration on it for now cause dont have the money to tune the car .. but for some reason im still geting a knock sensor light code 24 .. WHY ? bad motor of what ? please help ..
Solido78
knock sensor
Post by Solido78 »
Go to the parameters and select misc. and disable the knock sensor.
What ecu are you using?
Solido78
KNOCK SENSOR
Post by Solido78 »
TRY THE STOCK P61 PROGRAM.
monty
Post by monty »
well im using a P72 with S300 .. im try the stock p61 c what happen .. but i notice that i only get it the light when the motor is aroung 195F temp coolant ... thanks
Are you sure you have a knock sensor connected to the block? Do you have the knock sensor wiring connected? Post a picture of the inside of your ecu.
monty
Post by monty »
well this going to sound stupid but where is the knock sensor located ? to see if its on ... ill try to get some pictures tonyt .. and i try to datalog and record it but it doesn't work .. but its datalogging just not recording ..
Solido78
knock
Post by Solido78 »
If you have B18A or B18B block not use knock sensor.
monty
Post by monty »
well that could be my problem would that be a problem in a long run for me ? cause im starting to hear noises like a a screpping metal to metal
