AFCMD problems....
garagelife
AFCMD problems....
Post by garagelife »
my target air fuel ratio is 13.00 in columns 1-6, 12.5 in columns 7-8,and 12.00 in columns 9-10. after i turn on cloose loop,my afcmd show 14.59 and air fuel ratio stay in 14.59.....how to change the afcmd? please help thank you.
The target AF is calculated internally by the ECU and cannot be changed.
garagelife
thanks
garagelife
can i turn off cloose loop for street use? what air fuel ratio should i use for k24 with type r head? 13.50/13.00/12.50 ???
Yes, but you should not.
Ideal AF ratio for an NA engine under full load is around 12.8:1 - 13:1.
garagelife
appreciate that.
