I cannot seem to modify the rpm indexes. I would love to up the highest low cam index to like 2500 or so so I could keep my car from cutting fuel until 20kpa when below 2500. I set the low cam to all 20s and it has pretty much totally eliminated the headache of driving in first gear on the highway during stop and go traffic -- no more surging and bucking. The only problem is, I would like to persist that 20kpa setting a little higher into the rpm range, but the table indexes seem to not be editable.
Wayne
Fuel overrun cutoff tables
The kmanager help file seems to convey the message that it should be by instructing the end user to ensure that the rpm indexes always go from low to high.Hondata wrote:Sorry, the rpm index is not editable.
Are there any plans to make them editable?
Hondata, If You edit the KAL with notepad and modify the numbers
whats' happend ?? :roll:
Ex:
[Boost Level High]
; Gear,Pressure
0=1,9.79882604
1=2,12.00312104
2=3,15.01565754
3=4,15.01565754
4=5,15.01565754
5=6,15.01565754
[Boost Control Duty Cycle]
; Pressure,Duty %
0=4.94937704,15
1=5.16980654,20
2=6.05152454,30
3=7.44757804,40
4=10.68054404,50
5=14.79522804,60
6=18.02819404,70
7=21.99592504,85
[Overrun Cutoff Low]
; Rpm,MAP (KPa)
0=900,20
1=1000,20
2=1500,20
3=2000,20
[Overrun Cutoff High]
; Rpm,MAP (KPa)
0=1800,20
1=2062,20
2=2375,20
3=3000,20
Ex:
[Boost Level High]
; Gear,Pressure
0=1,9.79882604
1=2,12.00312104
2=3,15.01565754
3=4,15.01565754
4=5,15.01565754
5=6,15.01565754
; Pressure,Duty %
0=4.94937704,15
1=5.16980654,20
2=6.05152454,30
3=7.44757804,40
4=10.68054404,50
5=14.79522804,60
6=18.02819404,70
7=21.99592504,85
; Rpm,MAP (KPa)
0=900,20
1=1000,20
2=1500,20
3=2000,20
; Rpm,MAP (KPa)
0=1800,20
1=2062,20
2=2375,20
3=3000,20
