Hondata ECU for 00-05 S2000
1 Mar 2007
We are pleased to announce a programmable ECU solution for the 00-05 S2000.
Full details are at http://www.hondata.com/s2000kpro.html, but a summary is below:
- RSX ECU modified to suit the S2000 wiring harness.
- same features as the RSX KPro - covering big injectors, boost, nitrous, ITBs, boost control etc
- some mechanical components need to be updated to the 06-07 parts.
- will not work on the 06-07 (due to drive by wire)
- available mid June (estimated date only).
- price $1795 plus approximately $300 of Honda parts.
We would request that you do not call us for more information. We will do our best to answer any questions on this forum, and either update the page on our website or update this post. If there is something you desperately need to know - you've survived 7 years without knowing so far, just be patient.
Why K-Pro
Not to sound irrate but why use the rsx's ecu instead of using the existing S2000 ecu what were the draw backs and why is this system better. Thank you for you time :?:
Nasty 01 S2 with Vortech S/C with aftercooler pushing 496 with 14lbs of boost st8 bananas
Garrett_si
Garrett_si
Garrett_si
Garrett_si
Garrett_si
Garrett_si
I was wondering something that someone brought up. I'm still trying to figure this out. The problem is the ECU might report back an RSX vin, which will throw serious red flags as they give your s2k an obd2 inspection. Gotta find out from Hondata what the ECU reports as far as VIN.
I was hoping you could clear this up..any new info not on the page yet would be great....Thanks for your time.
