00 GSR
p-28
Im using an AEM UEGO wideband, running it in through the ANALOG 2 INPUT. The problem I am having is the resolution. There were only 12 spots (options tab/settings/analog input 2) in the conversion table for A/F Voltages=Values, the AEM has 32 conversians. When I datalog,.. all I get for A/F values are whole #'s (ex:12, 13, 15 not 12.8, 13.5, 15.1).
1.Is it necessary to "plug in" 12 conversians or do I just do the lowest a/f voltage and then the highest a/f voltage?
2.Since I am using an AEM and thats not one of the pre-selected widebands (in the dropdown box under the Wideband Lambda)do I need to select "custom" or one of the other wideband selections?
Voltage Offset for AEM UEGO (eld input/choose PLX wideband)
jordancivic
The gauge will read (for example) 13.7, while the Hondata datalog will read just 13. If the gauge goes to 14 though, so does Hondata. Like I said before, The AF on the datalog isnt wrong, it just isnt giving me a decimal point reading.
I dont see any reason why I cant use the ELD. Is that the input I am supposed to be using?
When we connected the analog input we had to remove resistor r2 and r3 from the board,.. I assumed that by doing that it would make the readings we got accurate.
jordancivic
jordancivic
Got it!!!
Connected to the eld input and "played" with the voltage offset till I got it right on. Heres the new calibration:
jordancivic
