USDM on JDM
Javcolin
USDM on JDM
Post by Javcolin »
Is it posible to use a USDM ECU on A JDM car?? cause i got the US ECU instead of the Square one for JDM will it work??? Thanks
They are interchangeable, just make sure you get the correct s300 for the ecu you have.
Javcolin
Post by Javcolin »
Thats good. now what calibration should i use. Stock JDM P30 or Stock USDM P30. since the engine is JDM or it doesn?t matter wich one to use?? thanks for all your help
It is completely up to you what calibration you start with. You just need to make sure you disable the sensors that your ecu does not have.
Javcolin
Post by Javcolin »
Thanks for your help, now how do i know which sensors are the ones my ECU doesn?t have??
Thanks again
You will get errors immediately if it does not have the sensors. Usually, ELD, BARO, Fuel Injector Error...etc.
Javcolin
Post by Javcolin »
Thank you very much. you have been very helpfull.
Javier
