Check it out, im a little worried about the high rpm knocks. Car is pretty much stock so I dont understand why im getting the knocks. I tried -2% ign in the knock areas and its still knocking. Also a/f seems a little choppy is that normal?
setup:
k24a1
stock header
ep3 manifold
exedy stage 2 clutch
rsx type s flywheel
cai
located in mass
choppy air/fuel...knocks
RobGiordano
RobGiordano
RobGiordano
RobGiordano
RobGiordano
Well i had to -4 ignition degrees in the areas of knock, and i messed wi the air fuel. the air fuel needs some more work, ill mess with it tomorrow heres the new kal and some more datalogs if antone wants to check them out. Thanks rensoyka! heres the new kal and some uphill datalogs
