check my data log and help please
06 nbp type s
i have a jrsc 06 rsx type s and am running 9 psi (i think seems to be some conflict as to whether my pulley combo makes 9 or 11 anyways,) i am running lean and get lean cut when accelerating towards boost. i have a zip with a half throttle run in 3rd from 3500 rpms until 7000 rpms and a 3rd gear wide open throttle pull from 3500 rpms until lean cut. im a tuning noob so if some one could help me as to where to add fuel it would much appreciated. btw i am getting a full tune next tuesday but dont want to be running lean till then, thanks guys
RobGiordano
06 nbp type s
RobGiordano
where did you get the map? im guessing it comes with your k pro. I dont have any k20z1 maps. Did you try uploading the map again? With the map hondata provides you should be able to do a wot run without hitting the lean protection. Base maps are usually set to be a little rich so you dont blow your car up.
RobGiordano
06 nbp type s
RobGiordano
06 nbp type s
RobGiordano
06 nbp type s
RobGiordano
06 nbp type s
RobGiordano
The calibration he started with was a street tune I did on a similar 05 for someone. As noted, it's not even in boost where the issue comes up, it's at the top of N/A. Also, the short term trims fly way north some times, and the o2 reads very lean, while so2 seems to indicate very rich. I think it's just a bad o2. He is getting a full tune from a tuner anyway so hopefully all will be revealed then. This calibration should be running rich if anything in columns 8-10.
Wayne
Wayne
The problem ended up being that the map sensor was not being fed from the output side of the blower -- the map sensor never saw boost. Bad o2 was ruled out by enabling the secondary o2 and seeing that even the narrow band thought it was flying way lean at the same times as the wideband.
