Plug gap when spraying NOS
SLO-FKR
Post by SLO-FKR »
I have a 99 Acura integra GSR. I need to know what gap to use on my plugs. When I spray nitrous.
Asc4130SD
Post by Asc4130SD »
I used the stock gap on my GSR .032,This is with the direct port NOS system (100HP). but i don't see any harm with going alittle bigger like .035 +/- .002 . The most important thing is making sure you get enough fuel, then reading the plugs is the next thing to pay close attention. and back the timing off a bit 2 to 4 degrees (retard) off base timing. Hope this helps :)
