I am having a problem with some rc750 sl4 injectors. They seem to be dumping way more fule into the engine then they should be. Has anyone else had a problem with these?
If at idle you are getting misfires, then retard ignition on 0 degree cam below 10 degrees. Otherwise, just take away some fuel from the fuel maps and call it a day.
ok after being up until 2am we found the problem. The customer brought us the car with the RCs already installed. The work we found under the tape and not good. Fixed now
