p0134 DTC w/ ver 1.6?
portandpolish
Post by portandpolish »
Unfortunately, for some strange reason it seems to be getting worse. here my Datalog, tell me what u think. My Kal hasn't changed by the way.
EP3, K20A, Toda Race Header, Injen CAI, IMG, K-Pro
The error code was already set when the datalog was made.
portandpolish
Hondata wrote:The error code was already set when the datalog was made.
Yeah, I noticed that as well, however the CEL came on around 2:35.835 in the datalog? How is that possible ?
I will try another datalog to see what going on. :cry:
portandpolish
Okay, Let's try this again. Here's a more concise datalog w/ the error. Thank you for your patients. As mentioned before it seems to be getting worse? Maybe we need to look at this problem from a different angle perhaps?
The o2 is taking a long time to heat up. Check all wiring connectors between the ECU and primary o2 sensor for corrosion (especially under the car), otherwise it could be the o2 sensor.
portandpolish
Hondata wrote:The o2 is taking a long time to heat up. Check all wiring connectors between the ECU and primary o2 sensor for corrosion (especially under the car), otherwise it could be the o2 sensor.
I see, I don't understand it taking a long time to heat up? When the engine is cold I don't get the error, however, it only happens when I restart a "warm engine." My O2 sensor is brand new, just bought from an Acura dealership; Do you think they might have sold me defective part?
