V1.2.1.6 (26 May 2006)
The main change is a much improved download function, which works with all the earlier uploads versions which I tried.
? Improved data integrity when downloading from the ECU which was uploaded with an old KManager version
? Allow KManager and SManager to connect to ECUs simultaneously
? Fixed datalogging problem when VTC is disabled
? Fixed nitrous operation on PNF ECU
? Added tip in ignition retard control to PNF ECU
? Added option to disable the idle valve for ITBs (PRB ECU only)
Use the built in 'check for updates' function in KManager.
locash
Post by locash »
Thanks Derek! The PNF group thanks you for getting around to that.. :)
Malaka
Post by Malaka »
"Allow KManager and SManager to connect to ECUs simultaneously"
What is this for?
KManager would identify the s300 as a KPro, and vice versa, so we changed the USB IDs to fix this.
Razathorn
Post by Razathorn »
Hondata wrote:KManager would identify the s300 as a KPro, and vice versa, so we changed the USB IDs to fix this.
Dohs! Somone coppied a h file ;).
Malaka
Post by Malaka »
OK, thanks.
thesilverbullet
Post by thesilverbullet »
'23 RDX SH-AWD
'07 S2K w/ JVT header, Berk 3" header back w/ TP Exhaust, AEM V3 CAI & Flashpro
'02 RSX-S w/cai/exhaust/dcrh/kpro - SOLD
hatchbacKed
Re: V1.2.1.6 (26 May 2006)
Post by hatchbacKed »
Hondata wrote: ? Improved data integrity when downloading from the ECU which was uploaded with an old KManager version
Installed this update and tried to donwload calib. from the ECU and I've gotten funky values for the Gear Comp>Gear ratios like 1=.0434, 2=47.104 and the fuel trim>inj. size value is 2000. I guess there are still some issues with data integrity downloads.
When installing these updates do I need to do Update Firmware on the ECU?
thesilverbullet
thanks for the update. maybe this version should have been a beta
'23 RDX SH-AWD
