Injector Data Question
rst3b
Post by rst3b »
Looking for some K-Pro injector setup help. Got an EP3 with a K24a2 swap. Adding Deatschwerks 440cc injectors in. When entering Deatschwerks injector data into the map the car idles very lean maxing out STFT adding fuel. Seems like the dead times or something is wrong.
Deatschwerks shows theses injectors flow at 505cc at the EP3s 51 psi fuel pressure.
In KPro should I input 440 or 505 for the injector size. Here’s what I input. Does anyone have these injectors? What’s your values in KPro?
Thanks for any help!
rst3b
Re: Injector Data Question
Post by rst3b »
Looks like the injector dead times needed to be increased about 15-20%. That seemed to help the situation and bring things more in line.
