iOS Applications
iOS Applications
With iOS devices you can either use the Hondata Mobile app, or use any app which uses the elm327 protocol.
To run the Hondata Mobile app you need the iPhone 4S and later, iPod touch 3rd generation and later, iPad 3rd generation and later. iOS 6 or later must be used. Many apps uses the elm327 protocol. The apps which we have tested are:
Gernby
Re: iOS Applications
Post by Gernby »
I was able to connect to my FlashPro from the Hondata Mobile app without any issues at all with my iPhone 5S, but could not figure out how to connect with DashCommand. Could you provide some tips?
'06 NFR S2000
DashCommand only works via WiFi. Your phone needs to be jailbroken and a BT to WiFi bridge installed. I used roqyBT4 & roqyBT7. The passcode also needs to be 1234
antkouv
Post by antkouv »
Is there an update on this? Can we connect an iphone to the Flashpro using Dash command?
antkouv
Post by antkouv »
Hello. Do you know if we can connect the flashpro to the Racechrono app?
vladvitt
Post by vladvitt »
antkouv wrote: Fri Jan 22, 2021 12:38 pm Hello. Do you know if we can connect the flashpro to the Racechrono app?
Hello, yes flashpro is able to connect and working with Racechrono.
I did it in in order to get logs from engimne ECU during track sesion.
There is onboard usinng flashpro + hondata https://youtu.be/TslQ3_2KK3M
Is only one thing have been occured, after some racechrono update the throttle opening maximium shows 76% only
ceruttibuilt
Post by ceruttibuilt »
I’ve had a problem with my new KPro v4 not working with the hondata app on my iPhone. I have 2 different vehicles both with KPro v4. It works ok with one of the kpros and not with the other one. Only physical difference I see between the board is the newer board has a way bigger chip that looks like it would be the Bluetooth adapter (has a built in antenna).My newer KPro serial number is 67652 which will not work with the app. My older KPro is serial number 60290. They both have the latest firmware available.
The issue with the 67652 KPro is the app will briefly connect but only display zeros on all sensors displayed, then keep disconnecting and reconnecting for about 2-3 seconds at a time. Any insight?
ceruttibuilt
Will do thank you
Touge_Chaser
Post by Touge_Chaser »
Anyone else having a hard crash trying to open dashboard? Has been working fine, but the last week I can’t access dashboard, all other menus work, can go into gauge list and see everything working and reading, but the second I try open a dashboard it hard crash’s out of the app? Have uninstalled and reinstalled, remade all my layouts etc, but as soon as it connects to ecu and try’s to display the gauges just quits.
What gauges do you have it set to display?
Touge_Chaser
Same as I had set before, speed, target o2, actual o2, voltage and short term %
What vehicle do you have and what Hondata system are you using?
Touge_Chaser
06 dc5 type r and kpro 4
