firmware update
panoramix3519
firmware update
my car is civic ep3 pra europe with kpro v4. I have changed laptop and to the new one i have installed the version 4.6.3 but to the old laptop i had the version 4.6.1 of kmanager. The first time i connected with kpro with the new laptop the kmanager told me to do firmware update and i press ok but from that moment when i plug the usb always says that the firmware in kpro is from a newer version and i have to update my software. i tryed update my software but it says that is the last one. i unistall the version 4.6.3 and install the 4.6.1 from hondata site and it says again the same and the button update firmware is greyed. I have tryed with the ecu unpluged from the vehicle and the same. With the ecu disconected from the vehicle when i plug the usb the green led is on for a second and them turns off and the red led blinks. What else i can do?
Re: firmware update
panoramix3519
Re: firmware update
I have done it but i have the same mesage again. I have tryed even my wifes laptop with new installation in case that mine have someting wrong. Is there any way to hard reset the firmware and uploade it again? I tryed reset ecu, leave it for 5 minute without power and again the same. The only thing i can do is the test upload and the car is working fine but with 2500rpm limiter. Please help is my daily car
panoramix3519
Re: firmware update
I dont know maybe from where can i understand this? In kmanager the button update firmware is greyed and when the ecu is disconected from the car and conect only the usb the green led is on for a second and then off and the red led blinks very fast?
Re: firmware update
Did you download the software directly form the link it the post above?
panoramix3519
Re: firmware update
Yes and i install it to two different laptops but no differense
Re: firmware update
panoramix3519
Re: firmware update
I have done it with detailed description. Is there any other way to reset the firmware or to force download the old one?
Re: firmware update
Please send it again since you have installed software from new link.
panoramix3519
Re: firmware update
i have done it again now with the new software and description and i am waiting for your answer. Please help me
panoramix3519
Re: firmware update
I see that to the same link has changed the build it is 4.6.3 but the build number is newer so i have tryed the new build 5845 if i remember right but its again the same problem
Re: firmware update
You are not using the correct version of software as the build number of the software you sent feedback from is older and not the one in this link: https://hondata.com/updates/KManagerV4-6-3.exe
You must use build 5845 and not earlier builds. Because you used software intended for one person you cannot go back in software or firmware.
panoramix3519
Re: firmware update
As i write you now i use the 5845 build and it does exactly the same thing. Nothing have changed
Re: firmware update
Please send feedback again with the version of software you are currently using.
