FlashPro standalone flash
ctr_uk
Post by ctr_uk »
Hi,
I recently picked up a FlashPro for my fn2, all works great except flashing without a laptop attached.
Whenever i try flash using the program button the rev counter will get to between 4k and 7k and then fall back to 0.
The car is in recovery mode. I have to go get my laptop, hook it up and hit upload, then it works perfectly.
Is this a bug? an issue with my FlashPro? or normal? any advice would be awesome.
The car is a 2007 ctr, it has a new battery, not low on charge or anything.
J
Re: FlashPro standalone flash
What is the serial number that is on the FlashPro?
ctr_uk
Post by ctr_uk »
Hi,
Version 4.4.70
Serial fp-si-int-22463
it flashes fine over usb but fails every time standalone.
Any help would be amazing, thank you
ctr_uk
Post by ctr_uk »
This is the error displayed when i plugged the flashpro into my laptop after a failed standalone flash.
Thought it night help.
Thank you
ctr_uk
Post by ctr_uk »
The error only occurs when used standalone, it flashes perfectly when hooked up to my laptop.
Will sending feedback provide anything useful? I'm happy to do it just thought id double check as the issue isnt an issue when the laptop is involved. Thanks again.
Yes, please send this as requested.
ctr_uk
Post by ctr_uk »
Feedback sent. Fingers crossed
ctr_uk
Post by ctr_uk »
Tried today on latest software/firmware, same result unfortunately. Luckily I can still hook up my laptop to use it.
ctr_uk
Post by ctr_uk »
Kindve good news.I thought I'd try powering the flashpro with USB power, standalone flash worked first try!
So if I hook USB up to my radio I can successfully flash the ecu.
I guess there's something wrong but this workaround works.
With the USB unplugged, try uploading from the FlashPro again and if it fails, send feedback again with a detailed explanation of the issue.
ctr_uk
Post by ctr_uk »
Just sent a fresh report directly after a failed flash. Hope it helps, thank you
