Honda R18 Crackle Tune
				YaBoiMyles954
Hi my name is Myles I have a Honda R18 VTEC engine in my 2009 Civic EX currently I'm trying to do a SI conversion while still keeping the R18 currently I have a DC Sports race header connected to the stock exhaust and a skunk2 stage 2 cam I was wondering if someone can smooth out the crackle tune I made and make it better
						Re: Honda R18 Crackle Tune
Im not expert in crackle tuning but on my 14 civic I have the low speed ignition set to -10 from 3500-5000 , with the first gear fuel cutoff set to 100ms , gives me a nice "woof" when I want
not sure if youre looking to have it as loud as possible, but this one is the best i was able to make it for my car. changed the water temp fuel compensation low to -10.2 across board, turned vtec off because the vtec cam on r18's are for economy and will lower ur power curve when its on. I changed your ign to -10 when you're completely in vacuum and have the fuel cut delay to 200ms on first gear and 300 on second. this will dump fuel into ur exhaust after you let off throttle. I also changed ur target air fuel ratio to 13.2 and ur wot target afr to 12.46 across the board. This will be for better performance gains.
				Tootinator
@Rippmatt Dude you're the GOAT. Tune is clean and exactly what I was looking for tysm
