B18C5 9:4:1 w JRSC9lbs fully tuned on dyno
This map was tuned by TURBOTUNE an authorized hondata dealer/tuner in NC. MY motor is a b18c5 type r head skunk 2 valve train tpe r crank 9 4 to 1 compression ratio. 84mm bore. rc 440 injectors w hondata s300,hondata p28 obd2b ecu. Hopefully this map will help you not have to spend money on the dyno like i did. good luck. this one's tuned w test pipe. the other file is tuned w cat.
