As is, with the FTS feature on, the throttle plate still closes when you shift and the throttle pedal is held at 100%.
Can the feature be modified so the throttle plate stays open with the FTS feature enabled? That would keep the car from falling completely out of boost in between shifts.
Maybe add some sort of ignition and fuel cut activated by the clutch switch?
I can do a FTS shift with the hondata feature off, and it will keep the throttle plate open, and stay in boost. Attached is the picture.
Fk8 Full Throttle shift feature request
Re: Fk8 Full Throttle shift feature request
Here’s a better picture that shows the throttle plate staying open during a Full throttle shift, with the hondata FTS feature off. This is a WOT pull from 2nd gear to 5th gear.
