Jumper J12 Need to be Removed for S200?
turbosi92
Post by turbosi92 »
:?: On the Hondata site, it says to remove Jumper J12 but I am reading and hearing that this isn't needed when installing a S200. I am getting ready to install my S200 and I want to prevent problems ahead of time instead of trouble shooting them. Should I cut it or not? Does it hurt if I do connect? What kind of problems would I experience if I didn't? I am just wanting to know what to look for.
Thanks in advance. :?:
s200 & J12
With the s200 remove J12. If you don't remove J12 connection reliability will be affected.
turbosi92
Post by turbosi92 »
So unhooking it can only help if I remove it. Correct?
Should I just unsolder it in case it needs to be put back on?
Doodoo
Post by Doodoo »
Just de-solder the resistor and have a friend pull it out at the same time. Before I took mine out my ECU Information(CTRL-M) would not populate and connections were bad. After I get info in ECU Information and I can connect much faster to Logger. RE is a different story though...
