terrorista
Posts: 38 Joined: Sat Jan 23, 2016 3:17 am
Post
by terrorista » Fri Apr 26, 2024 12:50 pm
Spunkster wrote: Fri Apr 26, 2024 12:29 pm
What wiring has been modified in the vehicle?
Adding some extra Data .. From the last car happening.
Please check the datalog .. First 10 sec the map is stuck. We took ou the connector, plug it again.. Re-fire the engine .. And the reading back to OK.
Posts: 24366 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Fri Apr 26, 2024 12:58 pm
calibration is locked
terrorista
Post
by terrorista » Fri Apr 26, 2024 1:08 pm
Spunkster wrote: Fri Apr 26, 2024 12:58 pm
My Bad ... Attached Unlocked ...
Post
by Spunkster » Fri Apr 26, 2024 1:18 pm
How exactly are the boost control and wideband wired.
terrorista
Post
by terrorista » Fri Apr 26, 2024 1:28 pm
Spunkster wrote: Fri Apr 26, 2024 1:18 pm
WBO with Analog channel direct to pin ...
BC have a fuse before entering B2, other terminal have a tic-tac switch to turn boost on and off aside the VSA switch, the ground used for it is from the body.
Post
by Spunkster » Fri Apr 26, 2024 1:38 pm
If these are all removed, does the same issue persist?
terrorista
Post
by terrorista » Mon Apr 29, 2024 4:48 am
Let me try that ...
The only strange thing is that this "lock" happens in other cars too.
terrorista
Post
by terrorista » Mon Apr 29, 2024 5:14 am
Spunkster wrote: Fri Apr 26, 2024 1:38 pm
Just Removed the wires ... Same Issue ... Just happens with 4bar map sensors. With OEM Map .. Nothing happens.
Attached the starting datalog wth cut wires.
terrorista
Post
by terrorista » Mon Apr 29, 2024 12:58 pm
What else can we test spunkster? Thanks
Post
by Spunkster » Thu May 09, 2024 9:49 am
I tested this in our 06 Si and it reads the 4bar as it should. I suspect there is some other cause on these vehicles.
